moonlightrunner
Apr 27, 2014Explorer
mowermech wrote:
Residential refrigerators are made to sit in one place, not bounce around on the road. That being said, apparently there is not a very high failure rate due to the bouncing, but I am unwilling to take the chance.
As has been previously stated, "To each his own". There is NO "right" or "wrong" about the issue, it is purely personal preference.
I put one of those cheap tiny cube refrigerators in an old popup. Oddly enough it was bounced around for 10 years before I replaced the popup. I also replaced a dead RV refrigerator with a small dorm unit that would slide into the same spot with a trim piece. Friend of mine replaced the broken Dometic in their vintage fulltiming Class C with an undercounter refrigerator stacked on top of an undercounter freezer in 2006 (I wish I had gotten a seperate freezer). It is still going with no problems. They also converted a schoolbus for fulltiming and built in two undercounter stcked refrigerators and an upright freezer (among other mostly residential stuff). They have had no problems. It is cheaper to replace the refrigerators since they will slip in/out the front door. The freezer would have to go out the rear emergency door the same way it was put in. I like those little $360 10cf Vissanis (24Wx25Dx60H) they have at home depot. When I convert (with help) my own skoolie, it will have one of those. It will go in/out a standard RV door (at worse might have to remove the doors). At the low price, I could, if needed, replace the tiny unit several times compared to replacing an RV refrigerator. But I live fulltime in my RV and only "boondock" one or two nights in parking lots, empty fields and no-hookup campgrounds before moving on. I do have a generator and a nice battery bank. When it's so hot that I need to run the rooftop AC, I am also powering the little dorm frige. Otherwise with no power, I move a couple of Nordic Ice packs from the freezer shelf to the refrigerator shelving.
What most anti-residential refrigerator people say is the energy use. If you read the FEMA pages, you will see that you can leave a refrigerator or freezer closed with no electric running to it for a day or two. My friends keep ice bottles and ice packs in their units. When traveling, they have traveled with no power in 90F for up to 8 hours and plugged back in to find no ice melt. They also have thermometers with exterior displays on the refrigerators/freezer. The freezer tends to stay at 0F or lower. The refrigerators are set at two different temps as one holds the beverages (water, juices, wines) at a lower temp than the upper refrigerator.
I believe you need to look at your needs and wants. Not all of us have the same needs and wants. So an RV refrigerator will not suit everyone. Just like a residential refrigerator will suit everyone.
38,782 PostsLatest Activity: Sep 01, 2026
