OhhWell
May 01, 2014Explorer
harold1946 wrote:lhatton wrote:
Don't bet on it.
Non generator trailers outnumber us 10 to 1 so I'm thinking absorption will be around for awhile.
And as a lover of the sights and sounds of the outdoors vs Mr Onan, I hope they do.
I believe you will find that most of those trailer ownwers also carry a portable generator.
Absorption refers require 12 volt dc to operate.
I used to be one of those and in that situation, an absorption fridge is still preferable even with a generator for most owners that dry camp. Yes, it uses 12v for the control board but not that much and so do a lot of other things. I never had an issue making it 24 hours on a single cheap semi deep cycle battery. Also, you don't often find room for more than 2 batteries on TTs and usually only a box for one from the factory. I do realize you can build a vented compartment for more batteries but they are going to outfit the trailers for the battery bank they leave the factory with and that will require an absorption fridge.
38,782 PostsLatest Activity: Sep 01, 2026
