moisheh
May 02, 2014Explorer
desret captain: I think you are missing some info.
1. Most owner conversions have been in DP's
2. Most DP's already have an inverter
3. If the existing inverter is not large enough then a simple 1000 watt unit can be dedicated to the fridge. No need to disconnect anything.
4. Modern residential fridges do not consume a lot of power. They also do not run constantly.
5. Samsung and Whirlpool with both honor the warranty and I bet others do as well. In our Dynasty the power to the fridge is seamless. When running down the road the inverter is supplying power to the fridge. When we connect to shore power the inverter stops inverting and the shore power takes over. The reverse takes place when we leave the CG. Nothing to turn on or off and nothing to disconnect. Next time you are in a CG I would suggest you seek out an owner who has done the conversion. You will be shocked to learn that it is a no brainer and that 99.9% of the owners are more than pleased. As I stated earlier a residential fridge is probably not a good option for TT's.
Moisheh
Moisheh
38,782 PostsLatest Activity: Sep 01, 2026
