holstein13
Oct 15, 2014Explorer II
JCGibson wrote:
Thanks for the info. My question about the large front windshield is does it get hot when going into the sun? Also, does the dash AC keep the front cool while driving or do you need to use the generator so can use the coach AC?
The huge front windshield has two things that keep it cool when traveling into the sun 1) there is an adjustable sun shade that you can use if you are staring at the sun and 2) the dash AC does a pretty good job of keeping you cool. You can point the vents right in your face and you can also turn on your coach's AC if you run the generator. So heat is not a problem up front.
