lakebum
Sep 02, 2016Explorer
Second Chance wrote:
You may need to look at an antenna/amplifier setup. Personally, I would not spend any money to pick up an unsecured campground wi-fi network - it's just not worth the risk from a security point of view.
Rob
Most public WiFi networks separate all traffic via a VLAN, that way nobody sees anybody. Have setup up a few public Wifi networks and security has never been an issue.
As far as the OP, the problem is your RV reflects the signal, so you do not so much need an amplifier, but an antenna on the outside to pickup the signal and bring it inside. Depending on what you use on the inside would determine what you need.
