jorbill2or
Sep 02, 2016Explorer II
usersmanual wrote:wolfe10 wrote:
I have used this very successfully for the last decade on the sailboat and in the motorhome to boost weak WiFi signals:
http://wavewifi.com/products/rogue-wave/
I don't think you can boost a wifi signal? would it not have to be the actual source that sets the signal strength?
I know little about such but understood theses device just are able to pick up a signal from a greater distance than your situated in
These Antenna and devices all receive a weak signal and boost it and in the example I ( and you ) pointed out send that to a router to "convert" it to a internal Pvt wifi in the rig . A somewhat secure way to use park wifi. they also ampliify the outgoing signal and direct it to the park ( or Starbucks or? ) system. Because you not only need to receive that weak signal you need to be able to reach it with your devices. I'm no expert but that's my understanding. Hopefully to OP has some things to check out
