wa8yxm
Aug 09, 2014Explorer III
katoomer wrote:
Just get a second receiver
Well with Dishnetwork even that solution has issues. but yes, that is way cheaper than a HDMI modulator.
The issue: Heaven forbid you and your partner wish to watch different shows.. UNLESS both shows are on the same bird, A DOME antenna can not do that... A dish can, but not a dome.
With a single receiver and the right dome.. No problem, but feeding the HD signal to the rear...
One option, you loose a bit of defination but normally the bedroom TV is smaller and thus you may not notice
Many receivers (Have not looked at the 211Z) (Downloading now) but you may be able to take either 3 or 5 lead to a lower cost modulator.
It has A/V out (Red/White/Yellow) so you can feed a standard DVD type modulator... Just loose some defination is all... Considering the difference in cost.. That or run a HDMI cable and splitter are your only options, Running that cable.. Easier than you think .
