Olddud
Oct 12, 2014Explorer
klutchdust wrote:Olddud wrote:
Wrangler, and no damage to it. HOWEVER, the back of the MH got rock damage in about 6 places, I am assuming by the tires of the Wrangler throwing back debris onto the MH. There is a lot of space between the bumper and fender of the Wrangler. I fixed it by covering that area while towing.
Interesting, hadn't thought of the MH. What did you do ?
I made a couple shields out of black acrylic, shaped them with a bandsaw to fit up against the back of the bumper, and wide and high enough to cover the tire, drilled three plastic pop rivet holes through the plastic and bumper, and stuck them on. I've had them on for about 2 years and have no further MH damage back there. The bumper has very thick plastic on the back side, so the rivets hold well. You can't really notice them all that much because they are the same color as the tires and all the other dark areas.
I made them tall enough to fit into a recess under the fenders, and this fit plus rivets makes them rock solid. They can be popped back off if you want, but I got tired of that and just leave them on all the time now.
38,782 PostsLatest Activity: Sep 02, 2026
