Rig - 2017 Winnebago (not so) Minnie Winnie 31K on 2016 E-450 chassis I have had my above rig for over two years now and love it, but man there sure is a lot of wind noise up in the cab. Has anyon...
When adding AT's to the rear of any rv, you have to take into consideration your awning arms. There is no point adding AT's between a vertical arm located and the rear of a coach because the arm is blocking airflow to the tabs. It might be useful if they were installed ahead of the arm. Im really not sure and when I called AT to ask, they really were not sure either but suggested in front of the arm.
