Gjac
Dec 28, 2015Explorer III
If I understand your above post each of your front tires carry 2320 lbs each with no variation from side to side. Your rears tires carry 2035 lbs each with no variation from left to right side, is that correct? If so I would try to shift some weight to the rear so that each tire carries the same load. Secondly I would measure the ride height in the rear and see if it is within range. I would measure it fully loaded. I am assuming that you have about 2.5 ins or more of ride height in the front based on your new springs is that correct?
