jspringator
Dec 28, 2015Explorer
I don't know how to measure the side to side weight per axle. The truck stops I've been going to don't give you that option. I'm going to try to put some weight behind the axle on the passenger side to compensate for the weight of the generator on the other side, but it won't be of much consequence. My water tanks are empty.
How do you measure the rear height? Top of pumpkin to frame? That should be at least 2 3/4 inches IIRC. I'll measure that today. I had 70 psi in the rear, I guess because of the warmer temps here. I lowered it to 60 psi in conformance with the build sheet from Workhorse.
I'm guessing this will make a big difference.
