rcload9's avatar
rcload9
Window frame not sticking
I have an almost one year old class a diesel that has black window coverings on the exterior of the windows. One of these has come loose and now blows around in the wind while I am driving. It looks like they use a sticky substance from the factory that is no longer sticking.
Does anyone have any suggestions on what product I can use to get it back to normal?
Pictures below, Thanks.
https://ibin.co/3D6VB8r6FtJL.jpg
https://ibin.co/3D6VUBfEhBfG.jpg
  • 3M VHB tape, I have a large solar panel held on the roof of our trailer with it.
  • Am I looking at that wrong? To me it looks like the window itself and it's just open. Close the window, problem solved.
    It sure looks like the new frameless window that's open to me.
  • MrWizard wrote:
    window frame ?
    don't you mean the black window cover {lexan ?}
    i would probably get a tube of BLACK polyurethane sealant, put a tiny bead around the frame where the cover is supposed to be
    press the cover on and tape it in place until the urethane set
    it won't be coming off
    or you can leave it at the dealers for a few weeks while they deal with getting the factory to cover the warranty repair
    X2. I have found a glue called "shoe goo" to be just about the best glue and sealant I have found. Incredibly strong yet still a tat bit flexible. It's like silicone on steroids.
  • window frame ?
  • 1 year old class A....start at the source. Probably a warranty issue. I'd call the dealer or manufacturer for a fix or suggestion.
