I have a 1999 Georgie Boy Pursuit. There is a water leak coming in at the top of the passenger side window. I took off the inside window frame and observed water seeping in and eventually running alon...
Putting band aids on is not the right way to fix it. Take the window out, clean the old dry caulk up, apply a bead of butyl putty tape, reinstal the window. Remove the excess squeeze out, apply a bead of Dicor around the top and sides of the window where it meets the side wall.
