I have a 1999 Georgie Boy Pursuit. There is a water leak coming in at the top of the passenger side window. I took off the inside window frame and observed water seeping in and eventually running alon...
We had that and took the window out and resealed/re-installed with butyl tape. Have also heard of water coming in around the running lights up top. You might want to check the caulk around them.
