dpscll wrote:
I have a 2007 Class A coach. The driver's side window has become cloudy and difficult to see through, especially when I need to see my rear-view side mirrors. It appears as though it is constructed of double-pane glass, so the problem appears to be inside. Can this problem be corrected or does the entire window need to be replaced? If replaced, who do I contact to do this type of work?
We also have a couple of windows that have fogged between the panes of glass. Many folks highly recommend Suncoast Designers in Hudson, Florida to do the repairs. They remove your window/s, repair them, and replace them. We plan to have ours repaired when we visit DW in the fall. They have RV sites and you stay there in your rig for a day or two while they do the work.
