atodalen
Nov 18, 2014Explorer
dbates wrote:
When I had to have both windshields replaced the glass place advised that the metal around the window was rusty and he's seen this and complete rust through on a lot of Winnebago’s. This fact has been testified to by many on this forum also.
Dave
As Dave said, the rusty windshield frame causing leaks on Winnebagos is fairly common. The rust has even been known to crack windshields. I had mine replaced last year and the shop had to do some rust remediation. Mine had started to leak prior to replacement. When I first noticed the leak, I removed enough of the screws in the paneling under the front cabinets to see where the water was getting in and also was able to see rust at that spot. I'd suggest that you not delay the fix very long if it is due to rust. It could turn into costly repair of the windshield frame if it continues to rust away. Best of luck---
Al
