J-Rooster
Nov 18, 2014Explorer
I have a 04 Winnebago with the same problem this past summer! The heat of the Southwest finally shrunk my windshield seals which caused a leak. I had Novus take the old seals off and inspect my entire windshield assembly! Novus found that I had a lower windshield frame rusting out. Novus didn't want to do anything with both split windshields since they are glued in from the factory. Trying to move a glued in windshield according to Novus would most likely (90% of the time) cause the windshield to break. The rusty bracket was still holding so I took a chance and had Novus reseal the windshield put in new moldings and of course they caulked everything. It worked they fixed the leak and just charged $100.00 Next time my windshield leaks,or is broken or cracked I'm going to have new windshield frame installed along with new windshields. In the mean time I bought a dehumidifier that I place between the split windshields when I'm not driving and that little machine is the best investment I have bought for my coach. I empty it once a week 3 to 4 inches of water that is not going down into my windshield assembly. When I'm in Arizona during the winter I do not run the dehumidifier due to the humidity in Arizona is 8%. Anywhere else I go when RVing that little machine is on 24/7.
