spotrot
Nov 19, 2014Explorer
I unscrewed and pulled the running light away. The outer calking had shrunk and failed. There was dirt behind the light but no real way for water to enter inside, so that's a dead end.
My upper molding must be different than the 04 because it's one-piece over both windshields and the center appears to be glue in. Also it looks like the large painted molding pieces on each side need to be removed. No clue how to do that.
The molding between the windshields became gummy and fell apart after a few years and the factory replacement is a flimsy plastic that doesn't fit well and flops about. That makes me want to get a new top rubber molding and make sure it's good before tearing out the old one.
To get a view of the inside of the cap, I'd have to tear out all the front cabinetry, TV, etc. SO my plan is to just tape over the upper molding and then water test it to make sure that leak is coming from there before creating a lot more work for myself.
