traveylin
Apr 14, 2015Explorer
Windsheild wipers are fairly simple systems. The steering arm off/on variable speed switch, A control box and the motor. I had trouble with mine and found that it was a loose 5 pin controller that connected the motor. I was able to get the ford test repair document for the wiper system and it was set up to id the defective component. What leads you to believe its the motor and not controller or column switch. Do a goggle search for F 53, f 550, f350 wiper problems and it should lead you to the test procedure. There was a portion of it free on line but I brought the pro direct from ford for the rv chassis
38,782 PostsLatest Activity: Sep 20, 2026
