Chevytrkr's avatar
Chevytrkr
Windshield wipers not working.
Tried to turn on my wipers this morning to clear the mist off my windshield. They went about a quarter of the way and stopped. Now they won't do anything. Could the problem be a fuse, or possibly the motor? I tried to locate the fuse box under the dash to check the fuse, but I couldn't locate the fuse box. Now what do I do? I have a 2014 Fleetwood Storm. Any Storm owners out there know where the fuse panel is. I need the panel with the fuse for the wipers. The chassis is a 2013 Ford Triton V10. Hope that helps.
  • Appears the problem was more complicated than I thought. Even the mechanic couldn't diagnose the problem until they called Fleetwood. Apparently Fleetwood routed the wiring through another system of relays that made repair more complex. It wasn't a problem with the Ford system, it was a problem with the Fleetwood system. So if you have a problem like this, have your mechanic contact Fleetwood.
  • the wipers on my Ford stopped working and the cause was the bracket that attaches the arms that move the wipers to the wiper motor broke. The first thing I would check is to turn on the wipers and look under the hood. See what is moving and what is not. In my case replacing the broken parts has been a little bit of a nightmare. They aren't Ford and had to be ordered from Thor. In the meantime I've used Rain X which works better than the wipers.
  • Only a suggestion ........ try rebooting by turning off and turning on the main electrial switch.
    Can you test if power is at the wiper motor? I have a tester that tests for 12 volt existance ... very inexpensive at an automotive store. I know sometimes wiring harness's are complex to follow back to a source.
    Just a thought!!!
  • I was having a similar problem with my MH. Washer would not work and only one speed on wipers. I checked all fuses which were ok....finally took to my mechanic and turns out it was a computer module. Really....for the wipers??? Ordered the part and works fine now.
