ichudov's avatar
ichudov
Windsor Monaco 40PST Headlight switch
During our first trip to FL, I realized that the headlight switch is not working correctly.
1. It was quite hot (or at least very warm) to touch
2. The knob that would adjust brightness of gauges, would only operate at certain positions and not other positions, the gauges would be dim, as if the rheostat switch had oxidized areas on it (I did not yet open the dash).
3. The headlights felt dim, not bright enough for a big vehicle like this.
4. The voltage gauge would drop to 10v from 13.5 as soon as the headlights would turn on (I know that 3 and 4 could be a separate issue)
As it seems to be easy enough to change, I wanted to ask where should I procure such things. I thought that I had a Freightliner chassis, and I was hoping that I could get them at my Freightliner dealer, I own a Freightliner semi truck in addition to this RV.
thanks
  • "ichudov".....Monacos are known to have undersized wiring to the headlights. The best fix is to add relays and tap into the wiring in your front run bay. On my 05 Diplomat I added the relays, new ceramic light sockets and Phillips quality bulbs.
    You can get all of this from Daniel Stern. Read the attached link. If you call him, he'll set you up with everything you need. One benefit of adding the relays....when I turned on my high beams, all four lights come on, instead of just the two high beams.
