kemer
May 13, 2015Explorer
Windy Driving
Just bought a new Winnebago Sightseer 35G and have noticed that when driving, you really feel the bumps and rattles. Now I expect that because it rides high, I would expect some bumps and not a totall...
Dale.Traveling wrote:kemer wrote:Yes you will have a front sway bar. Became a standard item several years back. As mentioned start with the low cost items first. Weight checked (with the coach loaded for an outing) followed by correct tire pressure and load balancing. Have the front end alignment, ride height and sway bar hardware checked. If you're still not happy then try a rear track bar.
My unit is a 2014 Winnebago Sightseer 35G. It has the Ford F53 chassis. Am I reading that there is a front track/sway bar?
Take the coach to a truck service center rather than RV service center. Use the people who focus in on the chassis and have the equipment/tools to correctly do the work. Save the RV service center for stuff above the floor.
