dougrainer
Nov 07, 2016Nomad
CA Traveler wrote:
Yes you can check channel 100 without activation of the receiver.
DTV would not install at my daughters because of the trees and it had nothing to do with falling leaves. If they can't give you a solid signal every day then they don't want the almost certain hassle of customers with marginal signal. But your experience may be different.
No longer can you check 100 or 200 without activation. You can check signal strength and transponder numbers. Maybe OLDER Direct receivers you can still get the "Info"(100/200) channel without activation. Doug
38,782 PostsLatest Activity: Aug 31, 2026
