caysea7254's avatar
caysea7254
Winnabego Vista
Does anyone fulltime in the Vista. We were wondering what is the horsepower and torque? What kind of gas mileage and how does it do in mountain driving. Thanks Tara
  • Thats why I worded it the way I did. Motorhomes are basically a year behind the chassis year, ie a 2020 Winnebago will usually bebuilt on a 2019 chassis. So,,, this year being a change year on powerplant from Ford, you have to be more specific.
    IF the OP is looking new, which engine becomes key.
  • wanderingaimlessly wrote:
    Depending on the year, hp, torque, and overall performance should be basically the same as all the other F-53 chassis units from them and the other manufacturers.
    If you are looking at new, it "could" be based on either of two engines, the old 6.8 V-10, or the new 7.3 V-8.
    But either way, it should not be appreciably different than other units from the same model year.
    you are. both are located with the first link. i checked the link after i posted and it was working. it isn't now. :h
    i think this is the data you're seeking:
    Highlights
    Fuel Capacity
    40 gallon, 55 gallon, 80 gallon
    Drive Type
    4x2
    Available Engines
    7.3L V8 Premium Engine/ 7.3L V8 Economy Engine
    Horsepower
    350 hp @ 3,900 rpm/ 300hp @ 3,750 rpm (Economy)
    Torque
    468 ft-lbs @ 3,900 rpm/ 425ft-lbs @ 3,250 rpm (Economy)
    Transmission
    TorqShift® 6-speed automatic with overdrive and tow/haul mode
    Wheelbase
    138", 158", 168", 176", 178", 190", 208", 228", 242", 252"
    Maximum Payload 18,720 lbs (F-53)
    Wheels Available
    16" Painted White Steel, 19.5" Steel, 19.5" White Steel Wheel, 22.5" Aluminum
    Warranty
    Bumper to Bumper 3 years / 36,000 miles Powertrain: 5 years / 60,000 miles Safety Restraint System: 5 years / 60,000 miles Corrosion (Perforation only): 5 years / Unlimited miles
  • Depending on the year, hp, torque, and overall performance should be basically the same as all the other F-53 chassis units from them and the other manufacturers.
    For 2020 chassis these are the Ford numbers with the 7.3 engine.
    Highlights
    Fuel Capacity 40 gallon, 55 gallon, 80 gallon
    Horsepower 350 hp @ 3,900 rpm/ 300hp @ 3,750 rpm (Economy)
    Torque 468 ft-lbs @ 3,900 rpm/ 425ft-lbs @ 3,250 rpm (Economy)
    Transmission TorqShift® 6-speed automatic with overdrive and tow/haul mode
    Wheelbase 138", 158", 168", 176", 178", 190", 208", 228", 242", 252"
  • Rk911 we wete at thst site. No info on horsepower or torque unless we r missing something.
