jeffmarschner wrote:
When you say to connect to the 12v main pin on your Onan generator, you are referring to the incoming 12 v pin, correct?
I am trying to set up a charging wire to my 2013 CRV. The pin on my connector is dead. based on the posts here and elsewhere, I am convinced it was never connected.
Just run this wire to the + side of my CRV battery with fuses at both ends?
JM
That is exactly what I did with our 2006 Sunstar. There was no power to the pin. Found this out when the battery in the jeep went dead 2/3 of the way to Tulsa! Corrected the problem there by connecting to the Generator 12v feed. Our new Sunova came properly wired.
