garyemunson wrote:
What I finally found was that the A/C-heater box is held to the front of the firewall with a number of 3/8 nuts. The box is plastic and has a rubber gasket attached to it that seals it to the firewall. Looking at the bottom of it from under the front passenger wheel well there appeared to be a gap between the gasket and firewall. I found a hacksaw blade easily slid in the space. Either the gasket had shrunk a little since the coach was built or the nuts holding the box to the firewall were never properly tightened. I suspect #2. I snugged up all the nuts and now do not have that gap. Waiting for another cold snap to see it that was all of it...
You may want to put some loc tite on them
