darsben
Sep 26, 2014Explorer II
Since you do not mention how old. I hope you re prepared to do a thorough predelivery inspection on the unit if used. Usually there is no warranty on a used rig even from dealer. If the rig is over 5-6 years old then new tires will probably be needed no matter how much tread on the tires. RV tires fail LONG before the tread wears out. So if your rigs tires are over 5 -6 years old by prepared to buy new. When you pick it up from a dealer all appliances, features must be checked. Refrigerator should have been on a minimum of 12 hours before you arrive so you can see it working. Furnace, Hot water heater etc. everything including the awning. This needs to take place before you give the dealer the money.
