- BZellerExplorerThanks for all the great suggestions!
- emiddlebExplorerUnless you go to the factory, Winnebago will probably point you to a local dealership.
You didn't say what year you have, but since you said 40J I'll guess 2002 based on the 40j floorplan. Here's some good references to get you started and to save for future problems...
If you go here Sales Brochures you can get your original sales brochure which has a lot of goof info.
Electrical, plumbing, paint etc has links to your various diagrams and other items.
Now, more to your question...
Parts fische had the general parts and diagrams for each floorplan
and finally, if you go here Specific build with your Advantage's serial # (not the VIN, the Winnie #) you can get a listing of all the parts used to build your specific RV, right down to the nuts and bolts. Between the two you should be able to figure out what you are missing and work with a dealership to see if its still available. As others have said, often a good cabinet shop can make you what you need, and the above references should show the what you are missing. - jhilleyExplorerSome of these are better than stock
Miller's Amazing Magic Table
Custom Wood Products
Marine and RV Tables - the_silverbackExplorerX2 on from Winnebago. At least check with them.
- smlrangerExplorerHave a good cabinet shop make and install what you need. Or, get a small wooden table and two side chairs. Many coaches now come with free standing table and chairs.
- Big_KatunaExplorer IIFrom Winnebago?
