jimbo98 wrote:
We have a 2008 24J diesel with a diesel generator too. Our 18 gallon propane tank will usually last about a month just running the fridge. Running the fridge and heater at night, it will last about a week. An option to driving to refill the main tank, would be to install a T fitting adapter at the propane tank. This way you could connect a spare 20 lb. propane tank if you main goes empty or if you just want to use the spare 20 lb. tank before you use the main tank. There are options...
Regards,
Jim
The later model (2011+) View/Navions have the LP tank mounted inboard of the chassis rails. There is no off the shelf "extend a stay" type device available for them. One must get creative to hook up external LP.
