FLSnowflake
Feb 23, 2014Explorer
Thanks for the input. We're unable to determine if we have a mascerator or not . . . we're told that we will have to pull off the cover of the Water Service Center and get behind it to find out. The other thing we think we've learned is that there is no way to empty the gray water tank if the Drain Pump malfunctions. We filled the gray water tank to Full and were still unable to get any gravity fed drainage - the gray water will only drain with the Drain Pump running, and you must manually hold down the switch the entire time. Until we learn differently, or can somehow correct the issues, these are two huge drawbacks to the View 24V, in our opinion.
