HawkTX
Feb 21, 2017Explorer
Winnebago VIEW tire stem HELP
I purchased a new 2017 Winnebago View. Love it so far! I went to check air pressure and the fronts valve stems are easy enough, but the back stems are almost impossible to get to. Am I really going to have to remove the rear hubcaps every time I want to check PSI or add air? What a horrible design. So then I did some research and some people say valve extensions are the solution and others say DON'T DO IT because they cause flats due to leak issues. I would really appreciate some insight on this subject from some of you experienced RV'ers.
Also, How do you remove the back hubcap/similator on these things? Do they just pop off with a hubcap tool? I didn't have much time to mess with it today, but I noticed a screw on it. Maybe I have to unscrew it to pop it off and then the outside cap. Here is a pic of it:
