- HikerdogsExplorerWe used our 2001 Adventurer for winter camping several times. We had no problems with temperatures in the 13*F to 17*F. The holding tank compartments are heated by air circulated from the gas furnace. You'll need to keep the thermostat set to 60*F or higher. In the low to mid teens the furnace will use a fair amount of LP.
You only have an 18 gallon LP tank, so you won't be able to stay more than a few days in cold temperatures unless you add something like an extend a stay valve and additional propane tanks.
Here's a link to an extend a stay propane valve:
http://www.walmart.com/ip/46529236?wmlspartner=wlpa&adid=22222222227034048351&wl0=&wl1=g&wl2=c&wl3=88147666128&wl4=&wl5=pla&wl6=122345382048&veh=sem - LadyRVerExplorer III used a 30B Sightseer, 2004 in 23-25° weather...no problems. Didn'the use the artic pac tank feature. Dumped a gallon pink stuff in black and gray tank, took fresh water hose off. Was good to go. That way for about a week. I am sure the tanks were enclosed.
38,763 PostsLatest Activity: Dec 05, 2025
