usersmanual
Oct 24, 2016Explorer
John&Joey wrote:
Old school logic.
If you live in cold country or the south then in the Fall. Get's all the acid out of the oil and won't run the risk of etching the main rod bearings.
If in the mid section of lots of freeze/thaw then in the spring before startup. Get rid of the moisture that can accumulate over the months that would tear up the main rod bearings.
YMMV
sorry man with todays oils and engine bearings there is no such thing
what moisture? where does it accumulate and how?
38,769 PostsLatest Activity: Apr 03, 2026
