usersmanual
Oct 25, 2016Explorer
John&Joey wrote:usersmanual wrote:John&Joey wrote:
Old school logic.
If you live in cold country or the south then in the Fall. Get's all the acid out of the oil and won't run the risk of etching the main rod bearings.
If in the mid section of lots of freeze/thaw then in the spring before startup. Get rid of the moisture that can accumulate over the months that would tear up the main rod bearings.
YMMV
sorry man with todays oils and engine bearings there is no such thing
what moisture? where does it accumulate and how?
Funny, where I'm sitting it sounds like you know just enough to be dangerous. Get a few more miles under your wheels and we'll talk about these great new engines you speak of.
could you let me know what brand mnotor does this? how many times you have experienced such and what particular years you had such happen
I have been alive 65 years worked as a mechanic and part time Rv tech
for 45 of those years.Owned and operated a engine rebuild shop
and have never seen nor heard of such a thing.
38,769 PostsLatest Activity: Apr 03, 2026
