xctraveler
Oct 27, 2016Explorer
wildmanbaker wrote:
Can you say, "Recreational Maintaince". Don't just look at Europe, a lot of transmissions here do not have a dip stick, so you must fill them from the drain bolt with a special adapter too prevent overfilling.
Took you at your word and looked up "Recreational Maintaince" (although I must admit I spelled "maintenance" correctly). I found no reference in the first two pages to any vehicle with an ic engine that does not have a dip stick - other than all electric (oh, right not an ic engine).
Further research using "internal combustion engine without a dip stick" turned up the following thread Eric the carguy
Must be a couple out there, but they seem to draw more ire than glory from posters.
38,769 PostsLatest Activity: Apr 03, 2026
