usersmanual
Oct 27, 2016Explorer
xctraveler wrote:wildmanbaker wrote:
Can you say, "Recreational Maintaince". Don't just look at Europe, a lot of transmissions here do not have a dip stick, so you must fill them from the drain bolt with a special adapter too prevent overfilling.
Took you at your word and looked up "Recreational Maintaince" (although I must admit I spelled "maintenance" correctly). I found no reference in the first two pages to any vehicle with an ic engine that does not have a dip stick - other than all electric (oh, right not an ic engine).
Further research using "internal combustion engine without a dip stick" turned up the following thread Eric the carguy
Must be a couple out there, but they seem to draw more ire than glory from posters.
he was referring to ""TRANSMISSIONS"" not Engines for what its worth although it really has zero to do with topic at hand here whatsoever
38,769 PostsLatest Activity: Apr 03, 2026
