Mile_High
Oct 27, 2016Explorer
rgatijnet1 wrote:You were supposed to put fluid in those power-slides!? :B
Way back in 1956 one of the Chevy V-8's that I restored had the factory AC and this meant no transmission dipstick and the only way to check and fill the Powerglide transmission was through a removable plug on the side of a special plate. The AC box under the hood prevented access to the dipstick so it was eliminated on some cars and just left inaccessible on others. You checked the transmission fluid just like the differential was checked.
I preferred when they didn't drop into gear until you hit 4,000 rpm. Could always catch rubber and smoke off of those nylon tires in the school parking lot, but you had to chain down the motor mounts or you would hit the fan shroud.
38,769 PostsLatest Activity: Apr 24, 2002
