Artum_Snowbird
Oct 05, 2013Explorer
Harvard wrote:
There is a plastic check valve behind the cone shaped debris screen of the city water inlet connection. The water should be drained from this check valve by using a small tool to release the valve from the out side (after removing the cone shaped screen).
Yes indeed, and only press the release button when there is no pressure behind the valve or it will be destroyed.
Once the release button is pressed, then start the pump with antifreeze in the line and once the antifreeze comes out the check valve, release the button and you are done.
38,707 PostsLatest Activity: Jan 05, 2014
