MountainAir05
Nov 01, 2015Explorer II
after in the pump stop. Hook up your air compressor and if you don't have a adapter get one. Hook up to city water connector , 40 lbs of air pressure and open each faucet till only air comes out. If you have a drain on hot water tank, open it also till only air comes out. Put two cups of antifreeze in each drain and More in toilet keep the seal lubed. ensure you open the drain on fresh water and drain. Your are finish. Others will add to what they do.
38,782 PostsLatest Activity: Sep 19, 2026
