wa8yxm
Oct 23, 2016Explorer III
Antifreeze? Why do you want to spend money on Antifreeze
Runroll the hose, unhook both ends, "Walk it" from the motor home to the open end to drain it, Then hook up an air compressor and blow it out.
Then open all valves on the motor home and blow it out (Drain whater heater and bypass first) cycle the Ice maker twice, and blow again, and again, (like 5 or 10 times) and finally put Antifreeze in drains and toilets only.
If the air ever freezes.. You won't be worried about the RV'
And come spring, you wont' have to get the taste of the Pink stuff out of the lines.
38,778 PostsLatest Activity: Jun 10, 2026
