SuperGewl
Nov 22, 2016Explorer
Well for one I hope you meant "Open the By-pass valve" and shut the inlet and outlet to the water heater. Now as far as the Ice maker, if you disconnect the inlet and outlet on the icemaker control valve and place the ice maker control arm in the off position you should be OK. Just make sure you wrap the ends of the lines in plastic or something to keep them clean. You can also stuff some insulation in the area of the control valve to help insulate it better.
I would have recommended using 25lb air to winterize with vice the RV anti-freeze. The recovery is easier and it's cheaper also. Just my .00001 worth.
