ksg5000
Nov 09, 2017Explorer II
Pressurized air should remove the water in your lines even if your not completely level - might take a little more time. Your BW/GW/FW tanks aren't impacted by the blow out. Assuming you drained your tanks you can add some antifreeze to BW/GW - and probably leave your FW alone so long as you leave your drain valve open.
38,769 PostsLatest Activity: Jun 25, 2013
