For those of you with a fairly new KEYSTONE product, your owner's manual has about two pages devoted to winterization, and explains both the 'wet' method and the 'dry' method.  It DOES make these statements:
- Use 30 psi max to blow out your lines (for dry method)
 - If you don't use the WH bypass, an additional 6-10 gallons of antifreeze will be required (wet method)
 - Pour an amount of RV non-toxic antifreeze into the fresh water tank . . . an alternative method is to attach a hose to the suction side of the water pump . . . (wet method)
So, apparently, Keystone indicates there's nothing wrong with either wet or dry method, pouring antifreeze in fresh water tank, in the hot water heater etc. , it's all acceptable.  Of course, each RV owner would want to follow manufacturer recommendations in the manual, if any.
