Dick_B
Nov 18, 2015Explorer
On my rig those valves are just to drain the water lines. There is another valve underneath the rig to drain the FW tank. It is usually called a petcock and the lever is rotated 180 degrees to drain. BUT the pink stuff should be pumped thru the system B4 opening those valves to keep pressure on the pump.
38,769 PostsLatest Activity: Apr 03, 2026
