Johno02
Nov 18, 2015Explorer
After opening the drains, be sure and open all Faucets so the water can drain out of the lines. Pull the plug on your water heater, and if you raise up on the pop-off valve, the tank will drain a lot faster. Then set valves to bypass water heater. Be sure to stand to one side, or you will have wet socks! There should be a drain for your fresh water tank, and probably one or more low-point drains, at least one for the hot lines and one for the cold lines. If you are going to use antifreeze. let everything drain good, then be sure to close the valve back. Depending on your vavle setup, you may be able to leave the drain for the fresh water tank open. I close mine back anyway, to make sure not critters crawl in.
38,769 PostsLatest Activity: Apr 03, 2026
