kioticoachman
Nov 19, 2015Explorer
The 2001 Coachman is set up with a gravity water tank fill & pressurized city water hook up. All went well, got the system filled using the water tank & pump to circulate throughout. HOWever, just to be sure the system was full I went to the pressurized city water hookup an removed the screen to get to the valve. This was suggested somewhere to make sure the antifreeze would come out the valve. Then, you would know the system was full. BIG mistake as when I pressed the valve the RVA gushed out an would not shut off until I shut down the pump. I presume that I will have to remove the water hookup on this unit to fix. The Forums thoughts an suggestions on how to go about to repair this. I feel pretty sure that the system will make it through the coming cold IF I remember not to turn on the pump in the meantime. Thank you. KC
38,769 PostsLatest Activity: Apr 24, 2002
