tomousecap
May 01, 2013Explorer
USARMYCW wrote:Dutch_12078 wrote:
I use lengths of foam pipe insulation to protect the wipers. I've also seen the same material used to cushion slide corners.
X2 :)
X3 and the tennis balls are not the answer because they don't stop the UV rays from hardening the wipers which is the real problem. If they remain soft they will work OK. :)
I got six stitches last time I bumped my head on the slide.. Ouch!!
I use the foam pipe for the slide also.
38,777 PostsLatest Activity: May 24, 2026
