Clay_L
May 02, 2013Explorer
tomousecap wrote:USARMYCW wrote:Dutch_12078 wrote:
I use lengths of foam pipe insulation to protect the wipers. I've also seen the same material used to cushion slide corners.
X2 :)
X3 and the tennis balls are not the answer because they don't stop the UV rays from hardening the wipers which is the real problem. If they remain soft they will work OK. :)
I got six stitches last time I bumped my head on the slide.. Ouch!!
I use the foam pipe for the slide also.
I use both foam and tennis balls. Foam for UV and balls to keep the wipers from taking a set.
My blades are almost ten years old and still work fine.
38,769 PostsLatest Activity: Apr 24, 2002
