KansasRV
Jun 15, 2016Explorer
tred0956 wrote:
I installed the wired Rear View Safety from Costco in my Class C and I love it It was a bit of a hassle running the wire from the camera to the monitor, but remember that you will need to run a power cable to the camera and another to the monitor even with the wireless model. I mounted the camera high on the back wall and I ran my wire through the back wall, sealed well, and through overhead cabinets to the cab. I used an ignition on source for power so the unit works whenever the key is on, makes a good rear view mirror when driving.
The wireless model says that it does not work well with aluminum, so if your MH is aluminum clad or fiberglass with an aluminum frame, I would be concerned. I would go with the wired model.
I agree with this advice, a wireless system can have interference if there is aluminium present.
Let us know what system you end up getting!
38,782 PostsLatest Activity: Aug 31, 2026
