fcooper's avatar
fcooper
Explorer II
Feb 13, 2014
Wiring the Bi-Directional Isolator Relay diesel-2
My coach does not charge the chassis batteries when on shore power, it just charges the house batteries.
I'm considering replacing the currently installed Intelletic Relay Delay (charges house batteries when alternator output is sensed) with the Bi-Directional Isolator Relay diesel 2 (BIRD).
The service manual for the BIRD states
When the generator is operating, a 12 volt signal is applied to the generator input. This inhibits the isolator from operating. This is to prevent the generator/converter combination from supplying power to the chassis
functions which might over-load the converter or the generator circuit breaker.
The wiring diagram simply shows a connection between the terminal on the BIRD and the generator, but provides no information on where to connect this wire to the generator. If you want to see the wiring diagram I've found, it's at link to service manual
I have searched for installation instructions, but the best I can find is the service manual in the link above.
If any of you have installed one of these Bi-Directional Isolator Relays, can you help me understand how the wiring is connected between the Bidirectional Isolator Relay and the generator. I have a 7.5KW diesel generator.
Thanks
Fred
  • There is a newer revision of the BIRD manual (rev B) which has revised voltage values and a more complete schematic. Doesn't help with the generator connection but does show the ignition and emergency start switch better.
    BIRD Diesel 2-rev B
    There has been some discussion about this generator connection on this site and iRV2. Mainly centered around the ability (or lack thereof) to charge chassis batteries with the generator in the event of an alternator failure while on the road. Haven't had to deal with that issue and have had good luck with our OEM installed BIRD Diesel 2.
  • The attachment point on the BIRD requires 12V. Most of them are wired to the line that feeds the generator hour meter.
